Manipulating Metadata and Annotations
This tutorial demonstrates using Repository Access to work with metadata and annotations. Code samples show how to create a template, add fields to the template, modify field properties, assign a template to a document, modify field data, apply a stamp to a document, and add a sticky note to a document. See the tutorial on general entry manipulation for actions not related to metadata.
The example code snippets in this topic comprise one continuous C# program.
Signing in
Start a session in a repository named myRepo located on a Laserfiche Server named myLFServer, signing in with the credentials myUsername and myPassword.
using (Session mySession = new Session())
RepositoryRegistration myRepoReg =
new RepositoryRegistration("myLFServer", "myRepo");
mySession.LogIn("myUsername", "myPassword", myRepoReg);
Creating a new template and saving it
Create a new template, assign the existing fields “ID” and “Author” to the template, set the “Author” field to be listed first in the template, and save the template.
TemplateInfo myTemplate = new TemplateInfo();
myTemplate.Session = mySession;
myTemplate.Name = "New Template";
myTemplate.AddField("ID");
myTemplate.AddField("Author");
myTemplate.MoveField("Author", 1);
myTemplate.Save();
Editing field properties
Modify the definition of the “ID” field as follows. Set the width of the field to be 7 characters, assign it a default value, mark the field as mandatory (meaning every document with the field must have the field filled in), constrain the field value to be of a certain format, configure an error message to be displayed when that format is satisfied, rename the field, and save the changes.
FieldInfo FI = Field.GetInfo("ID", mySession);
FI.ChangeType(FieldType.String);
FI.Length = 7;
FI.DefaultValue = "123-abc";
FI.IsRequired = true;
FI.Constraint = @"\d\d\d-\w\w\w";
FI.ConstraintError = "Invalid format for ID";
FI.Name = "Identifier";
FI.Save();
Assigning a template to a document
Assign the template to an existing document named “Doc”. The entry is retrieved as EntryInfo and cast to DocumentInfo here so it can later be used to call GetPageInfo, a method specific to documents.
using (EntryInfo myEntry =
Entry.GetEntryInfo("\\Doc", mySession))
DocumentInfo myDoc = myEntry as DocumentInfo;
myEntry.SetTemplate("New Template");
myEntry.Save();
Adding fields to a document
With the document myEntry still open, add additional field data. This snippet adds two fields not part of the template, with corresponding values, to myEntry. Note the two different ways of adding a new field.
FieldValueCollection FVC = myEntry.GetFieldValues();
FVC.Add("myFieldName", "DesiredValue");
FVC["anotherFieldName"] = "anotherDesiredValue";
myEntry.SetFieldValues(FVC);
Applying a stamp
Apply a user’s private stamp named “Personal Stamp” to the document myEntry. The sample enumerates through the current user’s private stamps and applies the stamp that matches the name “Personal Stamp.” This snippet then sets the stamp to be red in color, positions the stamp to be 200 pixels from the left border and 3000 pixels from the bottom border, and applies the stamp to Page 1 of myEntry. To choose a public stamp instead, use EnumPublicStamps instead of EnumPersonalStamps.
StampInfoReader ListOfStamps =
Stamp.EnumPersonalStamps(mySession);
foreach (StampInfo SI in ListOfStamps)
if (SI.Name == "Personal Stamp")
StampAnnotation SA = new StampAnnotation();
SA.StampId = SI.Id;
SA.Color = LfColor.FromAbgr(255);
LfPoint PT = new LfPoint(200, 3000);
SA.Position = PT;
PageInfo PI1 = myDoc.GetPageInfo(1);
PI1.AddAnnotation(SA);
Applying a sticky note
This next snippet applies a sticky note that says “This is a brand new sticky note” to the second page of myEntry. It sets a comment for the sticky note and positions the sticky note to be 900 pixels from the left and 900 pixels from the bottom.
NoteAnnotation NA = new NoteAnnotation();
NA.Text = "This is a brand new sticky note";
LfPoint point = new LfPoint();
point.X = 900;
point.Y = 900;
NA.Position = point;
NA.IsPrivate = true;
NA.Comment = "This is a short comment";
NA.KeepHistory = true;
PageInfo PI2 = myDoc.GetPageInfo(2);
PI2.AddAnnotation(NA);
myDoc.Save();
Retrieving field values
Retrieve field values from a document that has a multi-value field named FieldName. Print the field values to the console.
Entry.GetEntryInfo("\\MultiValueFieldDoc", mySession))
object fieldVal = myEntry.GetFieldValue("FieldName");
var values = new List<object>();
if (fieldVal != null)
var valArray = fieldVal as Array;
if (valArray != null)
foreach (object val in valArray)
values.Add(val);
else
values.Add(fieldVal);
for (int i =0; i < values.Count; i++)
Console.WriteLine(values[i]);
Retrieving dynamic field values
Retrieve field values from a document that contains dynamic fields. TemplateInfo.HasFormLogicRules indicates if the template contains dynamic fields. Iterate through each dynamic field and write the value of each dynamic field to a temporary string, then show the dynamic field names and values in a message box. The very last } closes the repository session created in the first snippet in this tutorial.
Entry.GetEntryInfo("\\DynamicFieldDoc", mySession))
TemplateInfo myTemp =
Template.GetInfo(myEntry.TemplateName, mySession);
if (myTemp.HasFormLogicRules())
FormLogicRuleInfo[] FormLogicRules =
myTemp.GetFormLogicRules();
foreach (FormLogicRuleInfo dynamicField
in FormLogicRules)
FieldInfo fielddata =
Field.GetInfo(dynamicField.FieldId, mySession);
Laserfiche.RepositoryAccess.Data.LfDataReader
data = dynamicField.GetDataReader(FVC);
string temp = "";
while (data.Read())
temp = temp + data[0].ToString() + "\n";
System.Windows.Forms.MessageBox.Show(
"Available Values For "
+ fielddata.Name + ": " + "\n" + temp);
