Key Concepts for Searching with the SDK
Important Classes
The Laserfiche.RepositoryAccess.Search class represents a search operation. Define the conditions of your search (which search terms, what logical connectives, where to look, and so on) using the Command property. See the Laserfiche product documentation for details on constructing an appropriate search command string for complex searches.
The Laserfiche.RepositoryAccess.SearchResultListing class represents the results of your search. Each result is presented as an EntryListingRow object. This objects contains columns that you may have specified in the SearchListingSettings class. EntryListingRow exposes several methods for getting column values. For example, to output your results into a text file, the EntryListingRow.GetDatumAsString retrieves the value of the column specified in its argument and formats it as a string for easy printing.
Using the SearchListingSettings class, you can specify which information to include as columns in your SearchResultListing object. You can also determine how to sort your results. A sample tutorial shows how to sort results on a column that contains date values. Remember to pass your SearchListingSettings instance into the Search.GetResultListing method.
Best Practices
The sample search tutorial uses a using statement to work on the SearchResultListing object. Laserfiche allows a limited number of concurrently open search result listings, so be sure to close open listings when finished. With the using statement, the listing is automatically closed when the program exits the statement.
Code Samples
See a brief tutorial with a code sample on searching with the SDK. See additional examples of search strings to illustrate more advanced search syntax:
- A table of search queries together with their LFQL equivalents.
The Laserfiche product documentation contains a reference on the Laserfiche Search Syntax.
See additional sample code for searching in the sample project repository.
