Getting Started with Client Automation
This tutorial demonstrates how to carry out actions in the Laserfiche Repository Desktop Client using the Client Automation Tools assembly. These actions include: opening a new client instance, reusing an existing client instance, opening folders, generating image pages, starting business processes, and viewing a document’s business process details. This tutorial primarily uses the ClientAutomation.dll assembly, but the snippet for viewing a document’s business process details dialog also uses Laserfiche.RepositoryAccess.dll. The example code snippets in this topic comprise one continuous C# program.
Signing in to a new instance of the Repository Desktop Client
Open the Repository Desktop Client and sign in to a repository. This code snippet first checks that there are no open instances of the Repository Desktop Client before opening the Client and signing in to the specified repository using a Laserfiche username and password. (To use Windows authentication, omit options.UserName and options.Password from the LaunchOptions instance.) Because the code opens a new instance of the client, there should only be one open window, the Folder Browser.
LaunchOptions options = new LaunchOptions();
options.ServerName = "myLFServer";
options.RepositoryName = "myRepo";
options.UserName = "myUserName";
options.Password = "myPassword";
using (ClientManager lfclient = new ClientManager())
    MainWindow FolderBrowser;
    if (!lfclient.IsClientOpen())
        ClientInstance singleLFexe = lfclient.LaunchClient(options);
        IEnumerable<ClientWindow> OpenWindows =
        singleLFexe.GetAllClientWindows();
        FolderBrowser = OpenWindows.First() as MainWindow;
Signing in using an existing instance
This next code snippet covers the case where there are one or more open instances of the Repository Desktop Client. If there are open instances, the snippet retrieves the first instance that it finds and signs in while making its main window the Folder Browser.
    else
        IList<ClientInstance> OpenLFClients =
        lfclient.GetAllClientInstances();
        ClientInstance singleLFexe = OpenLFClients[0];
        singleLFexe = lfclient.LogIn(options, out FolderBrowser);
This snippet demonstrates navigating to the folder with Folder ID 123456, then opens a document in read-only mode. Use the OpenOptions class to control which panes and tabs to open, the page to initially display, and the window position.
    FolderBrowser.SetCurrentFolder(123456);
    OpenOptions docOpenOptions = new OpenOptions();
    docOpenOptions.OpenStyle = DocumentOpenType.DocumentViewer;
    docOpenOptions.ReadOnly = true;
    FolderBrowser.OpenDocumentByPath("\\myFolder\\myDoc",
    docOpenOptions);
Generating image pages for an electronic document
This next snippet demonstrates how to generate image pages for an electronic document. Set ShowUI to true in order to display a progress dialog. The snippet tries to generate pages for the document with ID 789. GeneratePages takes a list of document IDs. In this example, the list contains one item.
Without specifying a specific image generation tool, CAT uses the Client’s PDF image generation tools to create the pages if document 789 was a PDF file. If document 789 were another kind of electronic file, CAT would have used Snapshot to print image pages for the file.
    GeneratePagesOptions options = new GeneratePagesOptions();
    options.ShowUI = true;
    System.Collections.Generic.List<int> docs =
    new List<int> { 789 };
    FolderBrowser.GeneratePages(docs, options);
Using Snapshot to generate pages for PDF files
Set the ForceSnapshot property to use Snapshot to generate pages for PDF files.
    GeneratePagesOptions SnapOptions = new GeneratePagesOptions();
    SnapOptions.ShowUI = true;
    SnapOptions.ForceSnapshot = true;
    System.Collections.Generic.List<int> SnapDocs = new
    List<int> { 123, 456 };
    FolderBrowser.GeneratePages(SnapDocs, SnapOptions);
Searching in CAT
CAT can also tell the client to run searches. This next snippet searches for all documents that have the “Forms” template and that have the status “Approved” in that template’s “Status” field. In this code snippet, the search results are displayed in the current client window, not a new window.
    SearchOptions searchOptions = new SearchOptions();
    searchOptions.Query = "{[Forms]:[Status]=\"Approved\"}";
    searchOptions.NewWindow = false;
    FolderBrowser.LaunchSearch(searchOptions);
Starting a business process
If your self-hosted Workflow installation is configured with workflow business processes, you can use CAT to start a business process in the client. You can use the business process’ name or its ID. Set ShowUI to false to skip the display of the confirmation prompt for starting the business process. This code snippet starts the business process on the document with ID 123.
    StartBusinessProcessOptions startBizOptions = new
    StartBusinessProcessOptions();
    startBizOptions.BusinessProcessName = "myBusinessProcess";
    startBizOptions.ShowUI = false;
    List<int> documents = new List<int> { 123 };
    FolderBrowser.StartBusinessProcess(documents, startBizOptions);
Viewing a list of available business processes
If you want to see the list of available business processes for a document, set the BusinessProcessName property to (none).
    StartBusinessProcessOptions bpOptions = new
    bpOptions.BusinessProcessName = "(none)";
    List<int> startbpdocs = new List<int> { 456 };
    FolderBrowser.StartBusinessProcess(startbpdocs, bpOptions);
Viewing a document’s business process history
To load the Business Process Details dialog for a document, you can invoke the ShowBusinessProcessHistory method. You need the entry ID and the business process ID. This sample snippet gets the ID values of all the business process instances on a document, then loads the Business Process Details dialog. This code snippet uses the RepositoryAccess library to get the ID values of business process instances on the document with entry ID 789. It then loads the Business Process Details dialog box for all these instances. The windows are positioned with their left, top, right, and bottom edges at 200 pixels, 200 pixels, 600 pixels, and 600 pixels respectively, and the false argument means that the windows are not maximized.
    RepositoryConnection CATconnection =
    FolderBrowser.GetCurrentRepository();
    ISession mySession = Session.CreateFromSerializedLFConnection
    (CATconnection.GetSerializedConnection());
    BusinessProcessEntityInfoReader availEntities =
    BusinessProcessEntity.EnumByEntry(789, mySession);
    foreach (BusinessProcessEntityInfo entity in availEntities)
        WindowPosition position =
        new WindowPosition(200, 200, 600, 600, false);
        FolderBrowser.ShowBusinessProcessHistory(789,
        entity.Id, position);
