Records Management Tutorial
This tutorial demonstrates common records management actions in two samples. The code snippets within each sample combine into one continuous C# program.
The first sample carries out the following actions:
- Create a new record series.
- Create a record folder.
- Create a disposition schedule.
- Apply the disposition schedule to a record series.
- Create a cycle.
- Assign a review cycle to a record folder.
- Freeze and unfreeze a record.
Connecting to the repository
Sign in to the repository myRepo using a Laserfiche account that has the Records Management privilege.
using (Session mySession = new Session())
RepositoryRegistration myRepoReg =
new RepositoryRegistration("myLFServer", "myRepo");
mySession.LogIn("myUsername", "myPassword", myRepoReg);
Creating a record series
Create a new record series in the folder “code name”, assigning it a code and a comment. Because the series has a code, manually prefix the series name with that code when creating it.
RecordSeriesInfo rsi = new RecordSeriesInfo(mySession);
rsi.Comment = "Sample description";
rsi.Code = "11-31";
rsi.Create(Folder.GetFolderInfo("\\code name", mySession),
"11-31 NewSeries", EntryNameOption.AutoRename);
Creating a record folder
Create a record folder under the record series created above.
Folder.Create(Folder.GetFolderInfo(
"\\code name\\11-31 NewSeries", mySession), "MyFolder",
EntryNameOption.AutoRename, mySession);
Creating a retention/disposition schedule
Create a disposition schedule with a 12-month retention period. Six months into the retention period, transfer the records to the location with ID 12345, retaining all records during the transfer. At the end of the 12 months, destroy the records and retain only their metadata.
DispositionScheduleInfo DSI = new DispositionScheduleInfo();
DSI.Name = "MySchedule";
DSI.Description = "6+6, destroy, keep metadata";
DSI.RetentionMonths = 12;
DSI.SetFinalDisposition(DispositionType.Destroy,
RetentionInstructions.RetainMetadataOnly);
DSI.AddTransfer(12345, 6, RetentionInstructions.RetainAll,
"The first transfer");
DispositionSchedule.Create(DSI, true, mySession);
Applying a disposition schedule
Apply the disposition schedule to the record series created earlier.
RecordSeriesProperties rsp = rsi.GetSeriesProperties();
rsp.DispositionScheduleId = DispositionSchedule.GetInfo(
"MySchedule", mySession).Id;
rsp.Save();
Creating a cycle
Create a cycle definition for use in a cutoff instruction. This sample creates a weekly cycle where records become eligible for cutoff every Wednesday.
CalendarCycleInfo cycle = new CalendarCycleInfo();
cycle.Code = "WED";
cycle.Description = "weekly cycle";
cycle.Type = CalendarCycleType.Weekly;
cycle.Add(DayOfWeek.Wednesday, "every Wednesday");
CalendarCycle.Create(cycle, mySession);
Assigning a review cycle to a folder
Assign a review cycle to the record folder created earlier, designating it as a vital records folder.
FolderInfo FI = Folder.GetFolderInfo(
"\\code name\\11-31 NewSeries\\MyFolder", mySession);
RecordFolderProperties RFprop = FI.GetRFProperties();
RFprop.ReviewCycleId = CalendarCycle.GetInfo("WED",
mySession).Id;
RFprop.Save();
Freezing and unfreezing a record
Create a record in the record folder, then freeze and unfreeze it. The final } signs out of the repository.
using (DocumentInfo docInfo = new DocumentInfo(mySession))
docInfo.Create(
"\\code name\\11-31 NewSeries\\MyFolder\\mydoc",
Freeze.Create(docInfo.Id, "Reason for freeze", mySession);
Freeze.Unfreeze(
"\\code name\\11-31 NewSeries\\MyFolder\\mydoc", mySession);
Putting sample one together
The snippets above combine into the following continuous program:
rsi.Code = "11-31";
rsp.Save();
cycle.Code = "WED";
mySession).Id;
RFprop.Save();
docInfo.Create(
Freeze.Unfreeze(
The second sample signs back into the same repository and retrieves the objects created in the first sample to work with them further. It carries out the following actions:
- Retrieve and modify an existing record series.
- Create a time+event cutoff instruction using a pre-existing cycle.
- Retrieve a record folder and apply a cutoff criterion to it.
- Assign dates to events in a cutoff criterion.
- Apply the cutoff criterion to a record folder.
- Carry out a transfer on a record folder.
- Confirm final disposition of a record folder.
Reconnecting to the repository
Sign in to the same repository.
using (Session newSession = new Session())
newSession.LogIn("myUsername", "myPassword", myRepoReg);
Retrieving and modifying a record series
Retrieve the record series created earlier, modify its comment, and save the change.
RecordSeriesInfo RSI = Folder.GetRecordSeriesInfo(
"\\code name\\11-31 NewSeries", newSession);
RSI.Comment = "new comment";
RSI.Save();
Creating a cutoff instruction
Create a time+event cutoff instruction using the cycle created earlier. Create a CutoffCriterionInfo object, assign its properties, and retrieve the ID of the previously created cycle. Add two events to the cutoff instruction, then create it using the CutoffCriterion.Create method.
CutoffCriterionInfo cci = new CutoffCriterionInfo();
cci.Name = "MyCutoffInstruction";
cci.Description = "A short description";
cci.RetentionType = RetentionType.TimeAndEvent;
CalendarCycleInfo MyCycle = CalendarCycle.GetInfo(
"WED", newSession);
cci.CalendarCycleId = MyCycle.Id;
EventInfo EI = new EventInfo();
EI.Name = "first event";
cci.AddEvent(Event.Create(EI, true, newSession).Id);
EI.Name = "second event";
CutoffCriterion.Create(cci, true, newSession);
Applying a cutoff instruction
Retrieve the record folder created earlier and apply the cutoff criterion to it.
FolderInfo RFI = Folder.GetFolderInfo(
"\\code name\\11-31 NewSeries\\MyFolder", newSession);
RecordFolderProperties RFprop = RFI.GetRFProperties();
RFprop.CutoffCriterionId = CutoffCriterion.GetInfo(
"MyCutoffInstruction", newSession).Id;
Cutting off a record folder
Set the events in the cutoff criterion to specific dates, apply them to the record folder, and cut off the folder once it becomes eligible.
int[] events = cci.EventIds;
for (int i=1; i <= events.Length; i++)
EventInfo eventInfo = Event.GetInfo(events[i-1], newSession);
if (eventInfo.Name == "first event")
RFprop.SetEventDate(events[i-1],
new DateTime(2017, 1, 1));
if (eventInfo.Name == "second event")
new DateTime(2016, 4, 8));
RFprop.Save();
RFprop.Refresh(true);
if (RFprop.IsEligibleForCutoff)
RFI.Cutoff();
Confirming transfers and final dispositions
Carry out the transfers specified in the retention schedule, then confirm final disposition of the record folder. The final } closes the using statement that began this sample and signs out of the repository.
DispositionScheduleInfo dsi = DispositionSchedule.GetInfo(
RFprop.DispositionScheduleId, newSession);
TransferCollection tc = dsi.Transfers;
foreach (TransferInfo ti in tc)
RFI.ConfirmTransfer(ti.Id);
RFI.ConfirmFinalDisposition();
Putting sample two together
RSI.Save();
"WED", newSession);
RFprop.Save();
RFI.Cutoff();
