Key Concepts for Client Automation
ClientAutomation.dll (CAT) is a .NET assembly that exposes an API for manipulating the Laserfiche Repository Desktop Client. In order for your third-party application to make calls using CAT methods, the appropriate files must be properly installed and registered on the desired workstation. For information on the files required to use CAT, please consult the Installing the Laserfiche SDK section.
To start using ClientAutomation, create an instance of the ClientManager class. ClientManager allows you to check whether there are any open client instances, get open client instances and windows, open and log in to a client instance, navigate to a folder, run Client actions on documents, launch Laserfiche Scanning, run searches, create custom toolbar buttons, and start and view business processes.
A tutorial on CAT covers actions in CAT other than creating custom toolbar buttons. There is a separate guide for creating custom toolbar buttons.
Classes
ClientAutomation has classes that represent additional aspects of the Laserfiche Client:
- ClientManager: Launches and finds Windows Client instances.
- ClientInstance: Represents a single instance of the Laserfiche Client (LF.exe).
- ClientWindow: Represents either the Folder Browser or the Document Viewer.
- DocumentViewer: Represents the Document Viewer window. Allows you to retrieve document properties. You can also export or print the document using this class.
- MainWindow: Represents the Folder Browser window. You can get information about the current folder, selected entries, and the window handle using
MainWindowmethods. OtherMainWindowmethods allow you to launch a search, launch Laserfiche Scanning, open and export documents, and generate pages on specified entries. - RepositoryConnection: Represents a single connection to a Laserfiche repository. One
MainWindowcan have multipleRepositoryConnections.RepositoryConnectionallows you to carry outRepositoryAccessactions by entering a specific session using a connection string retrieved from RepositoryConnection.GetConnectionString. The guide on creating custom toolbar buttons demonstrates how to do this. - CustomButtonInfo: Contains information about a custom button, such as its description, its icon representation, and the command it invokes. Used when you are creating custom buttons through CAT.
Sample Code
This repository includes ClientAutomation sample code for the following activities.
- Launching a client (ClientLauncher)
- Monitoring all open instances of the Client and printing details about open Client windows (MonitorConsole)
- Launching Laserfiche Scanning and scanning documents (ScanningLauncher)
- Adding custom toolbar buttons to the Client (CustomButtonManager). This sample demonstrates how to add an entire toolbar, with multiple custom buttons, to the client. We provide a simpler example of how to add one button, isolating the functions that use key features of
ClientAutomation, in the guide to custom buttons.
